Bryanfisher3000
Sep 29, 2021Aspirant
MR80 won't connect after power outage, again
Netgear MR80 not available as an option in the model number. After a very brief power outage our MR80 won't connect to the internet. I've tried doing the power cycling of the ATT modem and then ...
- Oct 01, 2021
Try this and see if it works for the MS:
What you need to do is factory reset the MS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the MS. Factory reset the MS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the MR.
Oct 01, 2021Guru - Experienced User
When you updated FW, did you update FW on the MS first then on the MR lastly?
Bryanfisher3000
Oct 01, 2021Aspirant
The router updated the firmware itself. I couldn't stop it. So yes, it updated the router first/before I ever had a chance to update the satelllites.
- FURRYe38Oct 01, 2021Guru - Experienced User
