wmgpYvH97
Feb 13, 2022Tutor
MR80 Won't connect to the Internet anymore (yes it is the router)
After wasting 4 hours of my day yesterday and now seeing that NG only provides support for 90d on their products. I thought I would write a post here. Long story short, I needed to move my cable mo...
Feb 13, 2022Guru - Experienced User
what modem/gateway from cox is it?
wmgpYvH97
Feb 13, 2022Tutor
It is a an ARRIS sb6183. Purchased outright by myself not from Cox.
- FURRYe38Feb 13, 2022Guru - Experienced User
Did you power OFF both ISP modem and MR80 for 1 minute then back ON with the modem first then the MR80...?
- wmgpYvH97Feb 13, 2022Tutor
Yes. At least a dozen times. Again, plug an old router in and no issue it works instantly. M80 =nothing.
Even plugged into the working router, it does not see Internet. It is like the Internet uplink port is defective or died or something?
- plemansFeb 14, 2022Guru - Experienced User
Try this last ditch effort.
Unplug the coax from the modem. Leave it unplugged for a couple minutes. Then factory reset the modem. Push and hold reset for 7-15 seconds while it still powered on (and unplugged from coax). Let it fully reboot. Then power it down for 2 minutes.
Factory reset the MR80. Push and hold reset while powered on for the same 7-15 seconds. Give it a couple minutes to fully boot and power it off.
Then follow this order.
Connect the coax back to the modem.
Power it on and give it 2 minutes.
Connect the lan cable from the modem to the wan port on the router.
POwer the router on and give it 2 minutes to fully boot.
Try to go through setup on the router.
