Henry1981
Apr 07, 2025Aspirant
MR80
Can I use the Nighthawk AX8 mesh extender with my MR80 mesh system?
Henry1981
Apr 08, 2025Aspirant
Sorry, I meant the MS and MR are compatible?
Apr 08, 2025Guru - Experienced User
The MK just implies its the full kit of MR and MS together.
But I've found that you can (sometimes) get the full kit for the same or cheaper as just buying a satellite. And then you have a backup router in case the primary fails. Stinks to have so much into satellites and the router fail and struggle to find a new router. I've done that with the orbi's.
- Henry1981Apr 08, 2025AspirantThat helps tremendously… I’m going to look into doing that, is there a specific place you recommend for me to find a reasonable priced MS system or just the general Amazon, Marketplace, ect? Thanks for your assist!
- plemansApr 08, 2025Guru - Experienced User
I'd look for used/renewed. They're not bad on jeff bezos market or even fleabay for used.
