smylesmccann
Jul 13, 2026Aspirant
MR80/MS80 speeds collapse to 5–7 Mbps until reboot
I have an MR80 router with one MS80 satellite. The system initially performs well after rebooting (with download speeds of over 500 Mbps even on Wi-Fi devices connected to the MS80 satellite), but af...
Jul 14, 2026Guru - Experienced User
Does this happen with a ethernet connected PC and wireless devices at the MR or just only with devices connected behind the MS?
Does this happen with the MS turned OFF?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many MS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
