LRoller
Jan 20, 2024Aspirant
MR90 Connectivity Issues
Installed the MR90 mesh system to replace an RAX120 router for increased coverage. Initially worked fine but was continuously experiencing intermittent connectivity drops from wired endpoints. I h...
michaelkenward
Jan 20, 2024Guru - Experienced User
I haven't seen that.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
