LRoller
Jan 20, 2024Aspirant
MR90 Connectivity Issues
Installed the MR90 mesh system to replace an RAX120 router for increased coverage. Initially worked fine but was continuously experiencing intermittent connectivity drops from wired endpoints. I h...
LRoller
Jan 21, 2024Aspirant
Endpoint IP address administration when use Router for DHCP option is selected is a function of the router code. I don't care how many people report the problem, it is a code bug.
Jan 22, 2024Guru - Experienced User
A factory reset and setup from scratch will need to be performed. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
