MGPowell
Dec 07, 2023Guide
MS60 - Constant white flashing light
Hi, The above satellite will not switch off blinking white, even if I try a factory reset that appears to do nothing. Have left on all night but no Blue or Amber light.. Any idea? Thanks...
Jan 07, 2024Guru - Experienced User
So with MS is same room as MR, factory reset the MS then factory reset the MR.
Wait about 5 minutes before you begin setting up the MR. After the MS and MR is reset, the MS should auto connect to the MRs default SSID broadcast and turn BLUE in front after about 5 minutes. Can you get to this point if the MS does this?
If it does, then you can begin the setup routine with a wired PC and web browser connected to 192.168.1.1.
