Bwheeler26
Jun 20, 2021Follower
MS60 Amber light, MR60 blue light
Hi, My router MR60 has a blue light and the internet is working, however, my satellite, the MS60 has an amber light and won’t work. I’ve tried unplugging it, holding down the reset button on the ba...
Christian_R
Jun 25, 2021NETGEAR Employee Retired
Hello Bwheeler26,
I would recommend performing a factory reset on the whole mesh system and running through the setup assistant again.
Christian
