dtalamantes10
Feb 16, 2022Guide
MS60 Amber Lights on All 3 Satellites, Blue Light on MR60. Satellites Have Internet.
We left for a short weekend getaway to find our internet was not working. We unplugged/plugged the modem and MR60 router and those fired up and worked just fine. I noticed two of the satellites had a...
- Feb 17, 2022I was having pretty much the same issues! Same diagnosis from yesterday evening. Thanks to your Post I got to the solution (with some extras) . The only step missing for you is to upgrade your MR60 firmware to 1.1.6.122. The MS60s are already ok.
So to sum up for the community:
- Upgrade triggered late afternoon yesterday.
- after this, Router kept blue led, 1 satellite was blinking white, 2 were steady amber.
- overnight after a couple resets, nothing happened and the connectivity was terrible!
- This morning after 2 straight hours (luckily within my stay at home holiday) I managed to confirm that: Router had not been well updated (and no upgrade was proposed by the system %#*#), the 2 amber led satellites were good with the 1.1.6.122 version loaded and running, and the white blinking m*** was not reachable (nothing, neither resets, nor direct 1 to 1 ethernet with laptop was effective).
This was it, the full diagnosis. Two upgrades, one to go and one damaged device. Now to the action.
- 2 Satellites were OK so no action.
- Router, upgrade thanks to downloadable package
- Damaged satellite (tricky one): access with direct 1 to 1 ethernet and TFTP file upload.
Here the links to the instructions I used:
* How do I upload firmware to my NETGEAR router using a TFTP client on Microsoft Windows? | Answer | NETGEAR Support
https://kb.netgear.com/000059633/How-do-I-upload-firmware-to-my-NETGEAR-router-using-a-TFTP-client-on-Microsoft-Windows
* How to enable TFTP client on Windows 11/10
https://www.thewindowsclub.com/enable-tftp-windows-10
* MR60 Firmware https://www.netgear.com/support/product/mr60.aspx#MR60%20(Mesh%20Router)%20Firmware%20Version%201.1.6.122
* MS60 firmware https://www.netgear.com/support/product/ms60.aspx#download
Good luck!
Feb 16, 2022Guru - Experienced User
dtalamantes10
Feb 16, 2022Guide
On the MR60: V1.0.6.110
MS60 Satellites: V1.1.6.122
- S_MillerFeb 17, 2022InitiateI was having pretty much the same issues! Same diagnosis from yesterday evening. Thanks to your Post I got to the solution (with some extras) . The only step missing for you is to upgrade your MR60 firmware to 1.1.6.122. The MS60s are already ok.
Good luck!- dtalamantes10Feb 17, 2022Guide
You my friend are a genius. Thank you!
You know what's funny? The technician told me that the firmware do not have to match!
Thank you! All lights are now blue! App is in working order!
- plemansFeb 17, 2022Guru - Experienced User
Glad it worked for you!
The satellites and the router should be on the same firmware.
did you try downgrading the satellites?
Thank you. I am good to go now after upgrading the router to the correct firmware as suggested by Miller.
Thanks for the reply.
