randymca
Jan 19, 2024Tutor
MS60 and MR60 on GS308 switch for backhaul - MS60 red light issue
want to put all my MS60's onto ethernet backhaul, cables are cat5E (tested), router/satellites on firmware=v1.1.7.134_2.0.65. connected the first satellite to ethernet like this and rebooted it: M...
- Jan 20, 2024
replaced all cables and switch and now its working as expected.
Jan 22, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
