enifsieus
Jan 03, 2022Guide
MS60 Flashing White (MR60 + 3 Sat Mesh)
One of my satellites is suddenly non-functional. The LED goes briefly solid white on boot, and then starts flashing white ad infinitum. Holding reset for well over 30 seconds does not seem to do any...
enifsieus
Jan 03, 2022Guide
Well, as I said initially, I have help reset for well over 30 seconds, and I don't see any indication of a reset/reboot/reset to factory defaults. It continues to sit there and flash white. A reboot does the same.
Is there a "no really, I wasn't asking" method to reset to defaults?
Lonestar9
Jan 27, 2022Guide
Did you ever get this resolved? I am having the same issue.
- FURRYe38Jan 28, 2022Guru - Experienced User
What FW version is currnetly loaded?
Have you tired the suggestions presented?
Lonestar9 wrote:
Did you ever get this resolved? I am having the same issue.- enifsieusJan 28, 2022Guide
I'm pretty confident that I tried the recommendations above exhaustively, with a number of variations and no luck ... I replaced the satellite, and things are working great again, though it was fairly frustrating that there was no apparent path to recover, or more completely diagnose the failure.
- Lonestar9Jan 28, 2022Guide
Thanks for the update. I was kind of hoping not having to do this, but it is what it is. Thanks again
- Lonestar9Feb 03, 2022Guide
I cannot access the satellite via ethernet(unrecognized) as we stated earlier it remains on an endless loop of blinking white
- FURRYe38Feb 03, 2022Guru - Experienced User
Even after factory resetting the MS and leaving a wired PC connected to it for 5 minutes you can access 192.168.1.250?
