LukeHoffmann89
Apr 07, 2024Aspirant
MS60 has a white blinking light and webui says it is offline
My MS60 has a white blinking light and im getting no signal from it. The web interface says that satellite is offline. Both my satellites are hardwired to a switch. Ive tried restarting the followi...
michaelkenward
Apr 07, 2024Guru - Experienced User
LukeHoffmann89 wrote:
It is only a couple days old everything worked when I installed it as of thrusday it is now sunday and one wont do anything. Is there a fix or shouldI send it back?
When you installed it, did you update the firmware on the router and the satellite? Those things get a bit funky when they have different firmware versions.
It the satellite wired to the router or connected by wireless?
Ive tried restarting the following:
MS60
MR60
Modem
Network switch
Did you do all that in the right order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on satellite, computers and rest of network.
What is the modem? Make and model?
What is the network switch and where is it on the network?
LukeHoffmann89
The modem model number is ET2251 not sure who makes it but is is the charter supplied one
