apat1678
Dec 30, 2022Aspirant
MS60 is connecting to another MS60 but not to MR60
Hi, I have one MR60 and two MS60 (Satellites) at my home. Both satellites (MS60) were connected to MR60 till last week. Last week, My MS60 (Satellite 2) was disconnected for week. I reset and n...
Dec 30, 2022Guru - Experienced User
Try powering off the satellite its connected to and see if it'll connect to the router.
there might be something blocking the signal and the satellite has a better connection.
- apat1678Dec 30, 2022Aspirant
Tried shutting off Sat 1. As soon as Sat 1 is up and running. Sat 2 disconnected from MR60 and connects back to Sat1. surprisingly, MR60 is next to Sat 2 and still connects to Sat 1 which is on second floor.
- FURRYe38Jan 02, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products ️
