ARockwell
Oct 14, 2026Aspirant
MS60 loops after update
After updating my MR60 and MS60 to V1.1.9.146_2.0.72 the satellites won’t finish booting up. On power it blinks white 13 times, pauses briefly, blinks 30 times, pauses, goes white for a moment, the...
ARockwell
Oct 15, 2026Aspirant
Thanks for the followups!
FrumpyGrandpa, yes, multiple times- reset for +30 seconds and 30-30-30. Unless there's another way to factory re-set it?
plemans, yes, hardwired on a tested cable to the MR and let it try for hours.
The MS just cycles. It came up after the update, even showed as connected in the MR admin page, but when I moved it it didn't come up. Now it only cycles- doesn't complete the boot.
Oct 15, 2026Guru - Experienced User
Did you reset both MS and MR and give 5 minutes to see if the MS would auto connect to the MRs default SSID name, prior to setting up the MR? With out the ethernet cable being connected. Have the MS in same room as the MR.
