ChicagOntarian
Oct 26, 2022Tutor
MS60 (MK62 Kit) / Satellites will not sync after automatic Firmware update to V1.1.7.132_2.0.64
Bought an MK62 mesh kit in June and couldn't be happier, good speeds, great coverage, easy to manage. Six days ago my satellites were both offline (orange indicator lights) and I have been unable to...
Oct 28, 2022Guru - Experienced User
Any progress on this?
ChicagOntarian
Oct 30, 2022Tutor
Thanx for asking Furry, but no. Please see my reply further down this thread. I have taken everything back to factory default settings and tried and re-tried but cannot get satellites to synce and form the mesh. Frustrated
- FURRYe38Oct 30, 2022Guru - Experienced User
Try downgrading the MR to prior version of FW and see if the MS reconnect:
If they do, manually update the MS first then the MR back to v.132:
- ChicagOntarianOct 30, 2022Tutor
Furry,
Thanx again.
This was your original suggestion which I did try, but nothing has gotten me to the point where either satellite will re-connect.
At a loss what to try next.
- mnzs-blenOct 31, 2022AspirantIf devices were working fine back then, it should work now too..
Did you all try the Sync by connecting the MR LAN port to MS LAN port while the internet is on via WAN port ?
