ChicagOntarian
Oct 26, 2022Tutor
MS60 (MK62 Kit) / Satellites will not sync after automatic Firmware update to V1.1.7.132_2.0.64
Bought an MK62 mesh kit in June and couldn't be happier, good speeds, great coverage, easy to manage. Six days ago my satellites were both offline (orange indicator lights) and I have been unable to...
Millard1982
Nov 06, 2022Initiate
Have you figured out a resolution to this yet?
I have been having nothing but grief with this system over the last few updates especially with changing the SSID and things not connecting through WIFI. I have also had the same issue as you and have probably spent a total of 30+ hours over the last month power cycling, factory resetting and downgrading firmware. If it is any help, the FW I have found with the least issues and keeps the connections working and most stable (the main thing to me) 1.0.6.116. Do everything through hardlines and do not use the app. Once everything is setup, then move the sats in the areas you want them.
