Bill_Wood
Nov 28, 2022Aspirant
MS60 no longer connects to MR60
I have had a mesh with 1 MR60 and 2 MS60 satellites for over a year. One of the MS60sstopped syncing with the router this week. The other one is working fine. I have tried various combinations of ...
- Nov 29, 2022
Might see if a 30-30-30 reset works.
If not, I would contact NG support and ask to see what your options are:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
Bill_Wood
Nov 29, 2022Aspirant
The connection using an ethernet cable does not sync either.
Nov 29, 2022Guru - Experienced User
- Bill_WoodDec 01, 2022Aspirant
Thanks. The 30-30-30 suggestion solved the problem. Appreciate the help.
- FURRYe38Dec 01, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
