casma164
May 01, 2022Initiate
MS60 satelite dead?
Satellite is plugged into an outlet. No light. Pressed the reset for 10+ seconds, no change. Nighthawk app shows it on the network map, but with a red indicating light and under devices, shows it...
casma164
May 02, 2022Initiate
Yeah, its the power supply. Swapped it with the working one and updated the satellite firmware.
Thanks for the help.
May 02, 2022Guru - Experienced User
Did updating and swapping back have it working?
Not sure what netgear's warranty is on power supplies.
Are you still within warranty? You could check with them if its not.
