Tanttila81
Nov 04, 2022Follower
MS60 satellite and PoE?
Does this satellite support poe if I connect some outdoor wifi extender to it which needs power over ethernet?
Tanttila81 wrote:
Does this satellite support poe if I connect some outdoor wifi extender to it which needs power over ethernet?Start with the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
For detailed questions about that device, try asking in the section where they talk about it.Nighthawk Mesh System - NETGEAR Communities
You might like to search there for messages related to your issue. - plemansGuru - Experienced User
No. the MS60 has no POE capability.
