BansheeVT
Jul 04, 2022Initiate
MS60 Satellite compatible with Orbi?
Is the MS60 Satellite compatible with Orbi Wifi 6 systems as a mesh unit? Specifically, the RBR750.
- Jul 05, 2022
No they're not.
Jul 05, 2022Guru - Experienced User
No they're not.
- michaelkenwardJul 05, 2022Guru - Experienced User
plemans wrote:
No they're not.
Is there a list somewhere that matches Orbi satellites with compatible routers?
That would be a way of dealing with this increasingly common question.
This is all I can find:
Are older Orbi WiFi satellites compatible with Orbi WiFi 6 Systems? | Answer | NETGEAR Support
- BansheeVTJul 05, 2022Initiate
Yep, that's the only thread I could find, and it really only specifically addressed Wifi5 vs Wifi 6 compatibility - come on, Netgear! A pinned post would probably be worth it...
- michaelkenwardJul 06, 2022Guru - Experienced User
Good thinking.
