Eusile78
Sep 08, 2024Aspirant
MS60 SATELLITE WONT SYNC TO MR60 ROUTER
HELLO my MS60 satellite keep blinking white all the time. i had the system working fine for a long time and i unplug one satellite to take it to another room and since then the satellite only bl...
michaelkenward
Sep 08, 2024Guru - Experienced User
Eusile78 wrote:
HELLO
my MS60 satellite keep blinking white all the time. i had the system working fine for a long time and i unplug one satellite to take it to another room and since then the satellite only blink white like trying to sync, this is 3 days ago.
Have you tried moving the satellite back nearer to the router?
Just another user with time on their hands.
Eusile78
Yes all the reset and unplugging I have done it with the satellite near the router and still the satellite is blinking white and no change, even i unplugged the other satellite and plugged in to the power and start blinking white then red and then blue just like it use to do the one that is not syncing.
- michaelkenwardSep 08, 2024Guru - Experienced User
Eusile78 wrote:
even i unplugged the other satellite and plugged in to the power and start blinking white then red and then blue just like it use to do the one that is not syncing.Not sure that I follow that.
Do you mean that the second satellite, the one that you moved, does connect when you turn off the first satellite?
- Eusile78Sep 08, 2024AspirantSorry about it, first satellite still work fine and syncing with no problem with or with out the second satellite in the network (the one that don’t work) first satellite is in a room away from router.
The second satellite is not syncing after I did several unplugs and factories resets (did the same thing to router at same time) it stay blinking white all the time.
I don’t know if you need more info?- michaelkenwardSep 08, 2024Guru - Experienced User
Eusile78 wrote:
Sorry about it, first satellite still work fine and syncing with no problem with or with out the second satellite in the network (the one that don’t work) first satellite is in a room away from router.My question was about removing the first (working) satellite from the network before you try to connect that troublesome one. Something a room away from the router seems a bit close. The WiFi should get that far without a satellite.
Do you actually need the second satellite?
And remember that whenever you play around with these things it is important to start the network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on satellite.
- Turn on computers and rest of network.
