Chilli71
Jun 30, 2021Aspirant
MS60 satellites link order
I have MK60 with 3 MS60. The ideal configuration would be that one satellite connects to each other. Instead one choses to go through two brickwalls with 2feet in total intstead connecting to the sa...
schumaku
Jul 05, 2021Guru - Experienced User
This can never be an ideal configuration - if you consider the packet from the last access point does travel over not less than five hops over the air, and over the very same channel ....
Chilli71
Jul 06, 2021Aspirant
Where is the problem if latecy is not critical?
How would you supply a long house?
Chilli
Chilli
- schumakuJul 06, 2021Guru - Experienced User
Chilli71 wrote:
How would you supply a long house?Version 1: Locate the primary device (the router) about half the way, and span the satelltes to both sides.
Version 2: Network cabling - copper or even fiber if distances require. The best investment ever. Now you cna run a wired backhaul.
Chilli71 wrote:
Where is the problem if latecy is not critical?Latency and the related highe performance impact is always an issue.
- Chilli71Jul 06, 2021AspirantIf I wire everything what do I need a Mesh network for?
I'm not free to select router place. It's next to the modem that is on the edge of the house that has the best receiption.
Of course I can do a wire from the modem to the middle of the house and then a backhaul wire back from the middle of the house to a satellite.
But making an installation through the complete house is exactly what you want to avoid with a Mesh system.- schumakuJul 06, 2021Guru - Experienced User
Chilli71 wrote:
If I wire everything what do I need a Mesh network for?The point is that _none_ of these WiFi Mesh systems in the market are true Mesh (in the sense of a mix and match and adopt the best connection) systems.
But also in commercial grade wireless [non-WiFi] mesh network planing you usually dont go beyond very few hops for performance and latency reasons.
All these consumer Mesh system wireless backhauls are simple enhanced extenders only. The Mesh term is coming from the seamless 802.11k and 802.11v WiFi roaming capabilities..
Chilli71 wrote:
I'm not free to select router place. It's next to the modem that is on the edge of the house that has the best receiption.Well, you are free - the cause is always bad planning. Reception - is this a wireless ISP site? The modem can remain at the best spot ... from there it's about planning and network design again. All you need is a dedicated link, or at least some MultiGig VLAN capable connection in my opinion.
Even the best and most sexiest WiFi Mesh system won't overcome the reality - which include walls, floors, .... Anything else is just marketing.
Even these consumer Mesh systems perform massively better is backed by a real wired backhaul. Still the same Mesh system, like your affordable Nighthawk Mesh MK6x or MK8x system.
But of course, at that point when it's about a central location with the possibility for deploying (cloud manageable) PoE+ or PoE++ switches, probably VLAN capable, you might consider deploying (cloud manageable) wireless access points like the Netgear WAX6xx (AX) ir WAC5xx (802.11ac).
