cherepanovs
Sep 15, 2026Aspirant
MS60 Stuck With White Light
Hi all, Hoping a moderator or Netgear staff member can help here--the online support portal won't let me open a case and I couldn't find a working contact form. Setup: MR60 + MS60 mesh kit, p...
FrumpyGrandpa
Sep 15, 2026Luminary
Page 12 of the MR60-MS60 User Manual indicates that a solid white LED is not one of the expected displays.
https://www.downloads.netgear.com/files/GDC/MK62/MK62_UM_EN.pdf
I'd say the chances of a positive response from Netgear are dim. If you were satisfied with the system, there are plenty of MS60 units on eBay for under $50.
