cherepanovs
Sep 15, 2026Aspirant
MS60 Stuck With White Light
Hi all, Hoping a moderator or Netgear staff member can help here--the online support portal won't let me open a case and I couldn't find a working contact form. Setup: MR60 + MS60 mesh kit, p...
Sep 16, 2026Guru - Experienced User
Try a 30-30-30 reset on the MS, if that fails to recover the MS, then you'll need to find another MS to replace the bad ones.
