JJROMANO
May 06, 2022Tutor
MS60 WI FI ROUTER WILL NOT ALLOW IP CAMERA CONNECTION OUTSIDE THE LAN
May 06, 2022Guru - Experienced User
1. what modem/gateway are you connected to?
2. what ip camera is it?
3. what firmware is on the router?
4. so if you're on your home network, it works fine? its just when you're off your wifi?
5. Are you using the ip camera's app?
6. did you check with the camera maker to see if there's any ports that needed to be opened?
