JJROMANO
May 06, 2022Tutor
MS60 WI FI ROUTER WILL NOT ALLOW IP CAMERA CONNECTION OUTSIDE THE LAN
May 06, 2022Guru - Experienced User
Its not the most secure but does it work if you put the camera's ip address into the netgears dmz?
JJROMANO
May 06, 2022Tutor
I will try that to rule out other issues. Thanks
- JJROMANOMay 06, 2022Tutor
DMZ connection does not work either
- plemansMay 06, 2022Guru - Experienced User
The dmz forwards all info from that ip address through the router. so it shouldn't be filtering anything if the devices ip address is set as dmz.
I am wondering if the Spectrum Modem is the problem. I don't have any access to the modem internals, it is proprietary to Spectrum. Does anyone have any knowledge of Spectrum ISP service issues?
