JJROMANO
May 06, 2022Tutor
MS60 WI FI ROUTER WILL NOT ALLOW IP CAMERA CONNECTION OUTSIDE THE LAN
JJROMANO
May 06, 2022Tutor
I will try that to rule out other issues. Thanks
JJROMANO
May 06, 2022Tutor
DMZ connection does not work either
- plemansMay 06, 2022Guru - Experienced User
The dmz forwards all info from that ip address through the router. so it shouldn't be filtering anything if the devices ip address is set as dmz.
- JJROMANOMay 06, 2022Tutor
I am wondering if the Spectrum Modem is the problem. I don't have any access to the modem internals, it is proprietary to Spectrum. Does anyone have any knowledge of Spectrum ISP service issues?
do you have ipv6 enabled?
And have you tried a different dns provider for both ipv4 and ipv6?
