lrsantos's avatar
Dec 24, 2022
MS70 Satellite Advanced Config Options
When I login to the MS70 Satellite and scroll down the screen, there is an "Advanced Home" section with a bunch of settings similar to the router.  Should I change any of these to optimize the system...
  • plemans's avatar
    Dec 25, 2022
    If its working fine, I wouldn't mess with it. I don't have the MK system but most mesh systems are designed to let the router manage the satellites for better speeds/efficiencies.
