lrsantos's avatar
Dec 20, 2022
MS70 Wired Backhaul still shows Wireless
I recently updated from the MR60/MS60 system to the MR70/MS70 system because I was having regular WiFi failures with the MR60 after having it for just over two years.  For the new MR70/MS70 devices I...
  • lrsantos's avatar
    lrsantos
    Dec 24, 2022
    I tested it with the cable that came with the devices, both locally and as a patch cable at the location and it showed as "wired" with that cable both times.  So it looks like it didn't like my old patch cable. .
