bulldog00
Nov 14, 2021Apprentice
MS80 backhaul issue
Hi all, I have the MK83 mesh nighthawk. I have one MS80 satellite hardwired for backhaul. However, I cannot get the satellite to show a “wired” connection type from its IP interface (or from the garba...
- Nov 15, 2021
quick follow up. Found a bad punch down on the keystone. Problem solved. Thanks again for the support!
You'd think as i am an IT Professional and have loss of feeling in my finger tips from terminating so many cables, id know better...
Nov 14, 2021Guru - Experienced User
It should switch to it automatically.
What does it show in the app and in the gui setup for the connection?
