bulldog00
Nov 14, 2021Apprentice
MS80 backhaul issue
Hi all, I have the MK83 mesh nighthawk. I have one MS80 satellite hardwired for backhaul. However, I cannot get the satellite to show a “wired” connection type from its IP interface (or from the garba...
- Nov 15, 2021
quick follow up. Found a bad punch down on the keystone. Problem solved. Thanks again for the support!
You'd think as i am an IT Professional and have loss of feeling in my finger tips from terminating so many cables, id know better...
Nov 14, 2021Guru - Experienced User
It should switch to it automatically.
What does it show in the app and in the gui setup for the connection?
bulldog00
It shows 5ghz for the connection type.
- plemansNov 14, 2021Guru - Experienced User
In both the app and in the gui?
- bulldog00Nov 14, 2021ApprenticeThat is correct. In both app and web interface it shows wireless backhaul.
whats the ethernet running through?
is it going through a switch, a patch panel, or is it a direct connection with ethernet cable?If you move the satellite to by the router and connect with a known good 6ft cable, will it show connected?
