bulldog00
Nov 14, 2021Apprentice
MS80 backhaul issue
Hi all, I have the MK83 mesh nighthawk. I have one MS80 satellite hardwired for backhaul. However, I cannot get the satellite to show a “wired” connection type from its IP interface (or from the garba...
- Nov 15, 2021
quick follow up. Found a bad punch down on the keystone. Problem solved. Thanks again for the support!
You'd think as i am an IT Professional and have loss of feeling in my finger tips from terminating so many cables, id know better...
bulldog00
It shows 5ghz for the connection type.
Nov 14, 2021Guru - Experienced User
In both the app and in the gui?
- bulldog00Nov 14, 2021ApprenticeThat is correct. In both app and web interface it shows wireless backhaul.
- plemansNov 14, 2021Guru - Experienced User
whats the ethernet running through?
is it going through a switch, a patch panel, or is it a direct connection with ethernet cable?If you move the satellite to by the router and connect with a known good 6ft cable, will it show connected?
- bulldog00Nov 14, 2021ApprenticeNo switch, no patch panel.
It’s run from the router to a keystone (using cat6) then from the keystone to the satellite (about 3ft patch cord).
Ethernet at keystone shows fine connection.
If I plug the satellite into the router using a 6ft good cable, I did notice it switched to “wired”.
