lKane
Dec 07, 2025Aspirant
MS80 firmware 1.1.8.20 (Dec 1st 2025) Bricked
Yes the firmware update did not complete on the second satellite. I have done every possible thing to connect with the satellite but it just blinks fast then slow in its never-ending cycle. Do...
CrimpOn
Dec 17, 2025Guru - Experienced User
There is an awkward situation with Netgear mesh systems which causes many models to lose communication if the router and satellite are on different firmware releases. This is why the procedure on page 93 of the user manual recommends changing satellite firmware before changing router firmware. i.e., changing the satellite firmware will cause communication to cease but it is "no problem" because in a few minutes the user will change the router firmware and communication will resume. If the current situation is the router and one satellite are on new firmware and the other satellite is on older firmware, then it will not communicate with the router. Thus, the process on Page 93 cannot function.
One potential solution is this:
- Connect the MS80 satellite to a computer using Ethernet. Both devices connected to nothing else.
- Set the computer to a Static IP address in 192.168.1.x that is not192.168.1.250. subnet mask 255.255.255.0
- Power on the MS80 satellite.
- Wait 2 minutes.
- Open a web browser on the computer to 192.168.1.250 and see if the MS80 satellite web page appears.
- Log in to the satellite
- Select Firmware Update from the menu and proceed to upload the extracted MS80 firmware image
- After the satellite reboots disconnect the Ethernet cable and set the computer back to normal DHCP addressing.
