lKane
Dec 07, 2025Aspirant
MS80 firmware 1.1.8.20 (Dec 1st 2025) Bricked
Yes the firmware update did not complete on the second satellite. I have done every possible thing to connect with the satellite but it just blinks fast then slow in its never-ending cycle. Do...
lKane
Dec 17, 2025Aspirant
Lastly I did do a 30 30 30 that I read about somewhere last week and I just read that that process has the potential to make this ARM based router junk.
Dec 17, 2025Guru - Experienced User
30-30-30 reset is safe on the MR or MS. I bought my MK63 series and had to do one 30-30-30 reset on it early on. FW would not take. After the reset was able to update using graduated FW files.
The 30-30-30 reset warning was for earlier generation routers.
