THEbarbarian87
Jul 14, 2021Aspirant
MS80 not reconnecting to MR80
This is a Tr i-Band 3 device system. MR80 is the router. 2 MS80 satellites. This was all setup and working. Then about after 10days the satellites stopped connecting to the router. If i hard wir...
THEbarbarian87
Jul 20, 2021Aspirant
Yes i did a factory reset and setup.
Was on firnware 1.1.4 doing the router update even when hard wired would not pull 1.1.5
I had to manually download and update both satellites and the router.
Had to hard wire this junk.
jspiers667x
Sep 09, 2021Aspirant
I woke up this morning to the same problem. It was up and running a bit longer than 10 days, but not by much. I haven't attempted a factory reset of the system yet.
Firmware: V1.1.6.6_3.1.93 (Updated a couple days ago)
- jspiers667xSep 09, 2021Aspirant
I reset the one of Satellites first with the reset button. That didn't resolve the issue with this satellite. I rebooted the router via the Web console. After doing that, the other Satellite connected and I was able to get the first Satellite resynced via the app. A couple of weeks in to this upgrade from an Orbi system that died after a solid 4 years of service. If this is going to be a constant struggle, it'll probably be time to change back to Linksys.
- FURRYe38Sep 09, 2021Guru - Experienced User
Have you tried re-loading FW using a wired PC and web browser to the MR and MS units, then after that factory reset the units. Turn them OFF for 5 miniutes then back ON and walk thru the setup wizard?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
- THEbarbarian87Sep 09, 2021AspirantConnection to the modem makes no difference because the main router keeps connection. It's the satellites that won't connect to the router.
If they are truly having the same issue.
Having to hardwire is the only way to cut out the stupid headache of the wifi backbone constantly breaking.
