TestUser12
Jun 02, 2024Aspirant
MS80 satellite is not syncing
I bought the Nighthawk Mesh Wifi system 4 months ago. Last month, one of the satellite was not able to connect to the router. I tried factory reset and connect it to the router using cable. But it do...
TestUser12
Jun 04, 2024Aspirant
The MS is not seen by MR even if I wire them in the same room, so I don't know the firmware version of the MS now. The MR fireware version is 1.1.7.12. Will try to reset them together.
Jun 27, 2024Guru - Experienced User
Any progress on this?
