phutch
Aug 30, 2020Follower
Need help setting up my home wireless network
We have a 6,000 sqft L-shaped house. Some rooms have a CAT5 connection to a central hub where our Cable Internet provider modem is located. Should I buy 3 nighthawks? or the mesh system? What's...
Aug 31, 2020Guru - Experienced User
I'd go with a mesh system. The benefit to mesh is the seamless roaming and single ssid function. it also gives you the option of wired and/or wireless backhaul. Plus you can add satellites to the system as needed for added coverage.
