dewey454
Dec 09, 2021Follower
Netgear extender 'stuck' with orange and blue lights on
My EV6250 extender seems to be 'stuck' with both sets of orange and blue lights on. Repeated restarts and attempted factory resets have done nothing. It doesn't show up in available networks either s...
Dec 09, 2021Guru - Experienced User
Check the user manual for LED behaviors.
Power OFF the EX for 1 minute then back ON.
Try a different power supply with same volt and amp specs.
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
