Barbino's avatar
Barbino
Tutor
Apr 18, 2022
Netgear mesh MR60 router
I have a new HP 6000e series printer and urchased the MR 60mesh router, and it has been a nightmare to get my printer to work. I did not know that this router did not interface with 2.4 ghz successfully…what a mess, I’ve been on tech support with my ISP and HP and Netgear for DAYS….isn’t this modern equipment?
  • FURRYe38's avatar
    Try turning OFF The MS and work with just the MR only with the printer.
    Ensure the printers FW is up to date.
    Try disabling wifi security on the MR temporarily to see if the printer connects at all to the MR. Reenable WPA2 and AES after checking this.
    • Barbino's avatar
      Barbino
      Tutor
      Finally solved! I worked with an excellent tech support guy ( Ranauk) who was able to fix this issue….after many contacts, finally got the right one to guide me through the connection issues.
      • fredboer's avatar
        fredboer
        Star
        Would you mind posting the solution in case it might help others?
