MartinCZ
Sep 14, 2022Aspirant
NetGear MR60 - SSH connection from Internet
Hi, I have Nighthawk® Mesh WiFi 6 System MK62. Router + satellite (connected via wire). Both running on latest firmware: MR60-V1.1.6.124_2.0.59. I use SSH connection inside my LAN to connect ...
MartinCZ
Adding info for my Internet connection:
I have FTTH connection to my home.
First device is: TP-LINK MC220L which is a media converter of SFP to RJ45. From this TP-LINK goes wire to my Mesh Netgear router.
Sep 14, 2022Guru - Experienced User
Did you disable uPnP on the MR before or after setting up any Port Forwarding rules?
Is any SPC or Armor enabled on the MR as well?
- MartinCZSep 14, 2022Aspirant
Hi, thanks for pointing me to the directions that might be the cause of the problem.
Info:
there are no parental controls nor Armor protection enabled. I also didn't apply any Static Routes, VLan/Bridge settings. IP6 is also disabled.
Port Forwarding rules were applied first and after that I noticed uPnP so I disabled UPnP in second step. I rebooted MR60 afterwards.
