MartinCZ
Sep 14, 2022Aspirant
NetGear MR60 - SSH connection from Internet
Hi, I have Nighthawk® Mesh WiFi 6 System MK62. Router + satellite (connected via wire). Both running on latest firmware: MR60-V1.1.6.124_2.0.59. I use SSH connection inside my LAN to connect ...
Sep 14, 2022Guru - Experienced User
Did you disable uPnP on the MR before or after setting up any Port Forwarding rules?
Is any SPC or Armor enabled on the MR as well?
MartinCZ
Sep 15, 2022Aspirant
Hi, thanks for pointing me to the directions that might be the cause of the problem.
Info:
there are no parental controls nor Armor protection enabled. I also didn't apply any Static Routes, VLan/Bridge settings. IP6 is also disabled.
Port Forwarding rules were applied first and after that I noticed uPnP so I disabled UPnP in second step. I rebooted MR60 afterwards.
