eloor
Jul 25, 2023Follower
Netgear Mr60 has been doing a boot loop/power cycling thing for past two days. Solutions?
I have a mr60 and 2 ms60 sats. The main issue seems to be with the mr60.
The modem lights cycle from dark to amber, to flashing white/solid white, then blue. It will stay blue and work normally for...
Jul 25, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- PartyfaulJul 25, 2023AspirantIbmve worked through most of thebutems above.
Our localnsmall business ISP uses a dish system, not really sure about their equipment name/style. But it has always worked and they put a new unit on my home last winter when I and the people who's signal bounces off my house were having troubles. All hard wired items work just fine no matter what the router is doing.
My home is 3 levels 3500ish Sq ft. Boxes are 25-30 feet apart. Have NOT tried the factory reset yet.
