gdb19
Oct 07, 2021Aspirant
Netgear mr60 mesh - Amazon echo issues
I’m having problems with my mesh WiFi and Amazon echo devices and wondering if anyone can help please. I’ve always had issues with multi speaker groups on Alexa with them intermittently not working...
- Oct 15, 2021
You can try using QoS and see if it works for you or not. Usually slower or moderate speeds QoS maybe handy. QoS is best for uplink speeds that are low. Whats your uplink speed?
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerPlease mark your thread as solved so others will know.
Oct 07, 2021Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
gdb19
Fury - Thanks for replying.
For the router I'm on firmware V1.0.6.116, for some reason I can't see the firmware version of either satellite. In the web interface on the firmware update page only the router appears and in the nighthawk app both my satellites show no connected devices and just a dash where the firmware version should be.
I did originally have this setup as an access point and switched to full functionality the other day by resetting the router. At the time I thought I may have to reset the satellites too but I didn't and they just connected. A NAS drive I have connected via Ethernet is also still working. Is there any chance I may need to reset the satellites? Just seems odd nothing is connected to them and I can't see the firmware version.
To answer the other questions:
I can't tell what make/model the ONT is that the router is connected to. All it has is an openreach label on it and a serial number - no make/model unfortunately.
I live in a 3 bed semi detached house and have a garden office. Between the router and satellite number 1 there is probably about 15 feet, more or less vertically - its positioned in this way so I can attach my NAS drive via Ethernet without having it in our living room (its a tad noisy). My other satellite is in the garden office and is around 30 feet horizontally from the router. With an external wall between them.
With regards to channels I was on auto for 2.4ghz and 40 for 5ghz, I mainly have iOS devices so don't have any way to scan for the best channels but have just switched to channel 6 for 2.4ghz and 48 for 5ghz to see if that helps. We do have neighbours using wifi - one directly attacthed to our house and another detached from us on the other side furthest from our router.
I have three amazon echo devices and individually they all connect to wifi and work fine, its just the combining them into a multi speaker group that doesn't work. I can sometimes get an option to combine 2 of the devices but get an error message saying network error in the Alexa app when i try to add the third. Previously Amazon had mentioned opening the ports from my first post so was wondering if it was the cause?
Thanks again, appreciate any help or suggestions.
