Dog101
Feb 06, 2024Aspirant
Netgear MR60 mesh router
Lost power and when it came on ,no WiFi. Followed the reboot directions light turned solid blue but no deviice could log into netgear network.just a spinning wheel. As soon as i unplugged the Ethern...
Dog101
Feb 09, 2024Aspirant
Our modem is a Motorola MB8611 which does not have a router built in, i will need to access the app to find out the firmware version but i was told that the router automatically updates to newer versions?
Feb 09, 2024Guru - Experienced User
If something is available or NG sets it up for automatic updates. If they don't, user can manually update FW on there routers:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
