acayci
May 14, 2026Tutor
NetGear MR60 Router - WiFi Connectivity Issue between two computers
Hello, I have a MacBook with WiFi to connect to Internet. I have another computer (Jetson) that is also connected to Internet using Wifi. They both are on 5 GHz. channel. I cannot ping from ...
May 14, 2026Guru - Experienced User
acayci wrote:I have a MacBook with WiFi to connect to Internet. I have another computer (Jetson) that is also connected to Internet using Wifi. They both are on 5 GHz. channel. I cannot ping from my MacBook to Jetson and vice versa. I can confirm both are in Access Control -> Security Allowed. Is there a Router configuration that I should be paying attention?
Is this a continuation of your older discussion thread?
- What firmware is the MR60 running?
- Can either machine ping the MR60 LAN address?
- Have you made sure that the Mac firewall doesn't have "Stealth mode" enabled? That would block Jetson attempts to ping the Mac (but not vice-versa).
- Are both machines connected to the same MR60 mesh element?
- Are both machines getting their IP addresses with DHCP?
FWIW, there is an old unresolved discussion thread here that is related:
- https://community.netgear.com/discussions/en-home-nighthawk-mesh-system/cannot-ping-the-device-in-same-network-mr60/2015192
If you are still running V1.1.7.134_2.0.65.2 firmware, then start by updating it.
- https://kb.netgear.com/000070298/MR60-MS60-Firmware-Version-1-1-8-142
FURRYe38 wrote:What platform is the "Jetson" computer?
Jetson is an AI platform made by NVIDIA. They run Jetson Linux (formerly called Linux for Tegra). This is derived from Ubuntu.
