acayci
May 14, 2026Tutor
NetGear MR60 Router - WiFi Connectivity Issue between two computers
Hello, I have a MacBook with WiFi to connect to Internet. I have another computer (Jetson) that is also connected to Internet using Wifi. They both are on 5 GHz. channel. I cannot ping from ...
acayci
May 14, 2026Tutor
Hello StephenB
Is this a continuation of your older discussion thread?
It is the same setup. The VPN service is still there. However now I am trying to connect the Jetson from my MacBook with WiFi because the Jetson is installed on the drone and there I need to be able to communicate with it in my back deck.
If you are still running V1.1.7.134_2.0.65.2 firmware, then start by updating it.
https://kb.netgear.com/000070298/MR60-MS60-Firmware-Version-1-1-8-142
I upgraded the firmware as mine was V1.1.7.134_2.0.65
Now I am able to ping Jetson from my MacBook. I am also able to ssh.
Now somewhat peculiar issue, one of the satellites wasn't able to come back online. It is having white blinking light.
Mustafa
- StephenBMay 14, 2026Guru - Experienced User
Great.
What have you tried (if anything) to resolve it?
