Davew954's avatar
Davew954
Netgear mr70 goes offline
Netgear mr70 goes offline every night and I have to manually reconnect every day and seems fine u till the next morning. I have had this system for 3 days and I am about to sent it back. Local cable company came out and modem is running fine and everthing else is good on their end. Is there a fix to this issue
  • michaelkenward's avatar
    michaelkenward
    Always at the same time?
    Does it lose the Internet connection or just local stuff?
    What does the modem show when this happens? And what is that modem?
    What firmware do you have on the MR70?
    Do the router's logs give any clues? In a web browser and the graphical user interface (GUI):
    • Advanced
    • Administration
    • Logs
    • Davew954's avatar
      Davew954
      I don’t know if it’s at the same time because I’m either at work or I’m sleeping.. The modem is fine if the brand new. Everything was working fine With my previous router. It’s definitely something with the brand new mesh system.. I have the newest firmware in the MR 70, How I just bought it and just set it up and it updated to the newest. I was recommended by my cable technician But I’ve had nothing but problems since I got it.
      • Davew954's avatar
        Davew954
        I have a red light on my MR 70 when this happens. None of my devices connect to the Internet, but they are connected to the MR 70. As soon as I do a manually reboot, everything is fine. It is quite annoying because I’m having to do this one to two times a day
