DanBlackaz88
Jun 16, 2023Tutor
NETGEAR MR80/MS80 (MK83) EasyMesh with VLANs
Hello, I have been using a NETGEAR MR80 Router (the Router of the MK83), firstly as my main router (Modem into the WAN port) along with two extenders NETGEAR MS80 Satellites both via a wired back...
- Jun 26, 2023
vlans are more business class devices and access points. The MK system isn't business class. Its consumer grade and its vlan's is just for IPTV setup, not using vlans on switches.
DanBlackaz88
Jun 24, 2023Tutor
But I don't understand why they worked without VLANs enabled and they were going through switches then?
Also if the tags are being stripped on the switch ports before going into the Satellites then they aren't really using a VLAN?
schumaku
Jul 03, 2023Guru - Experienced User
These MK83 kits don't need any VLAN configuration - a plain switch (with all access ports, pvid set to the VLAN ID) is perfectly sufficient to establish the Easy Mesh based wired backhaul.
No idea where from the VLAN configuration idea came from originally.
