Schellsbeer
Dec 30, 2024Aspirant
Netgear ms-80 loses signal
Hi, I have a netgear ms-80 satellite in my shop and I wanted to extended my wifi into my shed so I got another ms-80 but when I turn the new satellite on I lose wifi signal. The light goes from blue t...
- Jan 08, 2025So I tried the new ms and it works when the old one is unplugged. I also tried plugging the new ms in my basement while all the other satellites were plugged in and they all worked. So I’m guessing the chain limit of ms satellites is two
Dec 30, 2024Guru - Experienced User
What is the distances between the MR and this remote location?
Distances between the MR and MS should be good starting around 30 Feet. Building materials and distances will be a facotor on how MS work in remote locations.
