Schellsbeer
Dec 30, 2024Aspirant
Netgear ms-80 loses signal
Hi, I have a netgear ms-80 satellite in my shop and I wanted to extended my wifi into my shed so I got another ms-80 but when I turn the new satellite on I lose wifi signal. The light goes from blue t...
- Jan 08, 2025So I tried the new ms and it works when the old one is unplugged. I also tried plugging the new ms in my basement while all the other satellites were plugged in and they all worked. So I’m guessing the chain limit of ms satellites is two
Dec 31, 2024Guru - Experienced User
Seems like it.
I'd swap in the new MS with one of the other MS to see if it works correctly of it self.
Seems like maybe hitting over the limit on MS.
Schellsbeer
Jan 08, 2025Aspirant
- FURRYe38Jan 08, 2025Guru - Experienced User
Thanks for confirming this. Seems to be the limit as per the linked article.
Might try to see if you can install a non managed Gb LAN switch behind the MR and ethernet connect as many MS to the switch or MS that if need a 3rd MS at a remote location, ethernet connect it to this switch to avoid the 2 MS DC limitation.
Good Luck.
